[postgis-devel] ERROR: function extent(raster) does not exist
Sandro Santilli
strk at keybit.net
Mon May 2 06:20:37 PDT 2011
A lot of raster tests are failing here, pretty much
all due to 'function extent(raster) does not exist'.
Here's a list:
rt_above. failed (diff expected obtained: /tmp/pgis_reg_32471/test_28_diff)
rt_below. failed (diff expected obtained: /tmp/pgis_reg_32471/test_29_diff)
rt_contained. failed (diff expected obtained: /tmp/pgis_reg_32471/test_30_diff)
rt_contain. failed (diff expected obtained: /tmp/pgis_reg_32471/test_31_diff)
rt_left. failed (diff expected obtained: /tmp/pgis_reg_32471/test_32_diff)
rt_overabove. failed (diff expected obtained: /tmp/pgis_reg_32471/test_33_diff)
rt_overbelow. failed (diff expected obtained: /tmp/pgis_reg_32471/test_34_diff)
rt_overlap. failed (diff expected obtained: /tmp/pgis_reg_32471/test_35_diff)
rt_overleft. failed (diff expected obtained: /tmp/pgis_reg_32471/test_36_diff)
rt_overright. failed (diff expected obtained: /tmp/pgis_reg_32471/test_37_diff)
rt_right. failed (diff expected obtained: /tmp/pgis_reg_32471/test_38_diff)
rt_same. failed (diff expected obtained: /tmp/pgis_reg_32471/test_39_diff)
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
