[postgis-devel] [PostGIS] #878: ST_LineMerge with collection
trac at osgeo.org
Thu May 5 01:31:05 PDT 2011
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Description changed by strk:
Old description:
> According to GEOS dox about LineMerger:
> * Any dimension of Geometry is handled.
> * The constituent linework is extracted to form the edges.
> According to PostGIS manual:
> Only use with MULTILINESTRING/LINESTRINGs. If you feed a polygon or
> geometry collection into this function, it will return an empty
> GEOMETRYCOLLECTION
> Reality:
> SELECT ST_AsText(ST_LineMerge(
> 'GEOMETRYCOLLECTION(
> MULTILINESTRING(
> (1656318.45 4833344.45,1656321.79 4833339.62,1656312.54 4833333.49),
> (1656312.54 4833333.49,1656309.68 4833337.07)
> LINESTRING(1656309.68 4833337.07,1656318.45 4833344.45)
> st_astext
> (1 row)
> Basically, the MULTILINESTRING part was simply _discarded_.
> Works fine if the input is transformed in a MULTILINESTRING
> (without the collection).
> I'm not sure if the bug is in postgis or geos, will check.
> Surely dox of postgis and geos disagree on the matter.
New description:
GEOMETRYCOLLECTION
Reality:
MULTILINESTRING(
st_astext
(1 row)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/878#comment:2>
