[postgis-devel] [PostGIS] #939: ST_GetFaceEdges: wrong result on invalid topology-name
    trac at osgeo.org
    Thu May  5 13:05:07 PDT 2011
  Reporter:  aperi2007  |       Owner:  strk
      Type:  defect     |      Status:  closed
  Priority:  medium     |   Milestone:  PostGIS 2.0.0
 Component:  topology   |     Version:  trunk
Resolution:  invalid    |    Keywords:
Changes (by strk):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 You must have an old definition layout around. It's implemented since
 r7081 and you need to re-source topology/topology.sql after running make.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/939#comment:1>
