[postgis-devel] [PostGIS] #944: typmod support for PostGIS geometry
trac at osgeo.org
Mon May 9 22:32:16 PDT 2011
Reporter: robe | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
My gut feeling says we should keep AddGeometryColumn, populate etc. more
or less as is so they still do the add constraint thing and register into
geometry_columns or a new table called
geometry_columns_legacy;
So here is my thought for merging the old with the new world.
st_geometry_columns -- a view parallel in concept to geography_columns
that just inspects the catalogs -- perhaps just leaves out geometry
columns with no typmod info (or includes them I guess marking them as just
geometry). this is a true SQL/MM implementation.
geometry_columns -- a view that unions st_geometry_columns (except for
those just marked as geometry) with geometry_columns_legacy. So old
applications can continue to work as they did before.
The populate, addgeometrycolumns etc. will just populate
geometry_columns_legacy. We will expect all people expecting the new
behavior to use the typmod behavior for creating geometries. It would
also only add constraints to columns that don't use typmod construction.
Any thoughts / issues people see?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/944#comment:1>
