[postgis-devel] [PostGIS] #940: Can't compile PostGIS against PostgreSQL 9.1 beta1
PostGIS trac at osgeo.org
Tue May 10 06:50:52 PDT 2011
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by mcayland):
 In that case, the InvalidOid fix looks good to me. You'll need to put it
 inside a PGSQL_MAJOR_VERSION/PGSQL_MINOR_VERSION #ifdef to make sure it
 doesn't break older versions.
 If you'd like to propose a patch, I'd be happy to take a look.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/940#comment:9>
