[postgis-devel] [PostGIS] #846: Cleaning up around and enhance point in polygon tests around the code
PostGIS trac at osgeo.org
Wed May 11 13:30:24 PDT 2011
 Reporter:  nicklas      |       Owner:  nicklas
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by chodgson):
 #884 is actually just a logical error, there is a difference in the logic
 between point_in_multipoly_rtree and point_in_multipoly. I'll have a fix
 for it committed by tomorrow.
 #547 advocates removing the _rtree stuff entirely, as long as it is
 similarly quick to do point_in_poly tests with a prepared geos geom. We
 still need a postgis-level point_in_poly test for non-cached geoms though.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/846#comment:12>
