[postgis-devel] Change in PSC
Chris Hodgson chodgson at refractions.net
Wed May 11 16:09:00 PDT 2011
Nicklas Avén wrote:
> I just hope that a bigger PSC not will lead to less official information
> and more internal PSC information outside the lists.
I'd hope that a larger PSC would if anything make for less "internal
PSC" communications, if only because CC'ing a larger group becomes more
work ;)
On that note though, it would seem that the procedure used to
select/nominate the new PSC members was not quite what was documented in
my draft of RFC-1. I think the process in RFC-1, which is essentially
the same process in use by mapserver, gdal, geos, etc, is intended to be
entirely open, with all nominations and discussions on the -dev list.
Not that I expect the results to have been any different either way...
I'd just like to make sure the RFC accurately documents the process that
we would like to use. And I guess I'd kind of like to lean towards
openess... of course the RFC-1 voting process doesn't have any say as to
whether people might privately discuss nominations before they are made
publicly. And with 3 people on the PSC, the vote is just a formality if
the nominations have already been discussed at all.
Anyways, if anyone thinks the PSC nomination and voting process as
described in RFC-1 needs tweaking in light of the process used for the
recent PSC additions, now would be a good time to make those changes. :)
Chris
