[postgis-devel] [PostGIS] #940: Can't compile PostGIS against PostgreSQL 9.1 beta1
trac at osgeo.org
Wed May 11 23:10:23 PDT 2011
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by stl):
The patch will fail for all 9.1 alfa versions of PostgreSQL.
POSTGIS_PGSQL_VERSION parameter is the same for alfa and beta versions.
We need a better parameter which can differentiate between alfa and beta
versions
of PostgreSQL.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/940#comment:12>
