[postgis-devel] [PostGIS] #940: Can't compile PostGIS against PostgreSQL 9.1 beta1
PostGIS trac at osgeo.org
Thu May 12 00:03:43 PDT 2011
 Reporter:  robe     |       Owner:  robe
     Type:  defect   |      Status:  assigned
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Yah the EnterpriseDb already has their beta 1 build out which is what I'm
 using to test against.  So I try to keep the PostGIS experimental builds
 in line with theirs since most Windows users will get it from them.  I
 think the same is true with yum managed by Devrim -- but that is next on
 my todo to compile on my CentOS box testing with his 9.1beta yum install
 and then compile PostGIS 2.0 on that.
 So really there isn't a reason for anyone to be using an alpha build.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/940#comment:15>
