[postgis-devel] [PostGIS] #902: [raster] ST_MinMax
trac at osgeo.org
Fri May 13 15:13:55 PDT 2011
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: assigned
Priority: medium | Milestone: PostGIS Raster Future
Component: postgis raster | Version: trunk
Keywords: |
Comment(by dustymugs):
A set of ST_MinMax and ST_ApproxMinMax variations for processing
coverages:
1. ST_MinMax(rastertable text, rastercolumn text, nband int, hasnodata
boolean) -> record
ST_MinMax('tmax_2010', 'rast', 1, FALSE)
ST_MinMax('precip_2011', 'rast', 1, TRUE)
2. ST_MinMax(rastertable text, rastercolumn text, nband int) -> record
hasnodata is set to FALSE
ST_MinMax('tmax_2010', 'rast', 1)
3. ST_MinMax(rastertable text, rastercolumn text, hasnodata boolean) ->
record
nband is set to 1
ST_MinMax('precip_2011', 'rast', TRUE)
4. ST_MinMax(rastertable text, rastercolumn text) -> record
nband is set to 1 and hasnodata is set to FALSE
ST_MinMax('tmin_2009', 'rast')
Variations for ST_ApproxMinMax are:
1. ST_ApproxMinMax(rastertable text, rastercolumn text, nband int,
hasnodata boolean, sample_percent double precision) -> record
ST_ApproxMinMax('tmax_2010', 'rast', 1, FALSE, 0.5)
ST_ApproxMinMax('precip_2011', 'rast', 1, TRUE, 0.2)
2. ST_ApproxMinMax(rastertable text, rastercolumn text, nband int,
ST_ApproxMinMax('tmax_2010', 'rast', 1, 0.5)
ST_ApproxMinMax('precip_2011', 'rast', 1, 0.2)
3. ST_ApproxMinMax(rastertable text, rastercolumn text, hasnodata boolean,
nband is set to 1
ST_ApproxMinMax('tmax_2010', 'rast', FALSE, 0.5)
ST_ApproxMinMax('precip_2011', 'rast', TRUE, 0.2)
4. ST_ApproxMinMax(rastertable text, rastercolumn text, sample_percent
ST_ApproxMinMax('tmax_2010', 'rast', 0.5)
ST_ApproxMinMax('precip_2011', 'rast', 0.2)
5. ST_ApproxMinMax(rastertable text, rastercolumn text) -> record
nband is set to 1, hasnodata is set to FALSE and sample_percent is set
to 0.1
ST_ApproxMinMax('tmax_2010', 'rast')
ST_ApproxMinMax('precip_2011', 'rast')
Ticket URL: <http://trac.osgeo.org/postgis/ticket/902#comment:9>
