[postgis-devel] [PostGIS] #944: typmod support for PostGIS geometry
trac at osgeo.org
Mon May 16 05:48:11 PDT 2011
Reporter: robe | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by mcayland):
I think that if we went as far as having a hybrid solution, it would just
cause even more chaos in the long run. As Paul mentions up-thread, do we
want to be stuck with an ugly hack forever?
For point 1, converting a varchar(50) to a varchar(1000) can be done
easily with a single catalog query because the internal representation
doesn't change. In the same way that setting a typmod for a mixed column
can be done in the same way because by changing from a sub-class to a
super-class, we can guarantee that all of the criteria can be met and so
we don't need to check every single row. We would have to visit every row
if going the other way, but I don't think that's the common use case.
For point 3, I think we would need to see which tools have these issues in
order to get a feel for whether or not this would be a real problem.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/944#comment:17>
