[postgis-devel] [PostGIS] #950: Topology: LayerTrigger - wrong filter
PostGIS trac at osgeo.org
Mon May 16 06:39:07 PDT 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
 The LayerTrigger function in topology section actually use this code sql:
     query = 'SELECT * '
              || ' FROM ' || quote_ident(toponame)
              || '.relation '
              || ' WHERE topogeo_id = ' || OLD.topology_id
              || ' AND layer_id = '|| OLD.layer_id
              || ' LIMIT 1';
          --RAISE NOTICE '%', query;
 I guess the comparing between topogeo_id and topology_id is wrong.
 This could be allow/deny wrongly the deleting of some Layer.
 Also I guess the correct sql should be this:
   query = 'SELECT * '
              || '.relation '
              || ' WHERE layer_id = '|| OLD.layer_id
              || ' LIMIT 1';
 Because the topology is already the one when triggering this function.
 regards,
 Andrea.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/950>
