[postgis-devel] [PostGIS] #901: [raster] ST_AsGDALRaster and the helper functions ST_getGDALDrivers and ST_srtext
trac at osgeo.org
Mon May 16 19:00:07 PDT 2011
ST_srtext
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: | Keywords: history
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
* milestone: PostGIS Raster Future => PostGIS 2.0.0
Comment:
Bborie,
Does this work for you?
SELECT *
FROM ST_GdalDrivers();
I get an error almost like the order of the OUT arguments is wrong. Can
you confirm it works for you:
SELECT * FROM st_gdaldrivers();
Gives me error:
ERROR: invalid input syntax for integer: ""
This is running on windows.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/901#comment:8>
