[postgis-devel] [PostGIS] #901: [raster] ST_AsGDALRaster and the helper functions ST_getGDALDrivers and ST_srtext
trac at osgeo.org
Mon May 16 20:46:15 PDT 2011
ST_srtext
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: | Keywords: history
Comment(by dustymugs):
Replying to [comment:8 robe]:
> Bborie,
> Does this work for you?
> SELECT *
> FROM ST_GdalDrivers();
> I get an error almost like the order of the OUT arguments is wrong. Can
you confirm it works for you:
> SELECT * FROM st_gdaldrivers();
> Gives me error:
> ERROR: invalid input syntax for integer: ""
> This is running on windows.
Regina,
The function works fine for me in Linux. I'll do some poking at the what
could be causing that error.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/901#comment:10>
