[postgis-devel] [PostGIS] #954: [raster] ST_AsTiff syntax error
PostGIS trac at osgeo.org
Tue May 17 07:47:45 PDT 2011
 Reporter:  strk            |       Owner:  dustymugs
     Type:  defect          |      Status:  assigned
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 Can you try r7170?  The problem boiled down to modifying a function
 parameter in plpgsql.  PostgreSQL 9.0 permits it while 8.4 does not.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/954#comment:3>
