[postgis-devel] [PostGIS] #959: document topology.GetRingEdges
PostGIS trac at osgeo.org
Wed May 18 02:00:29 PDT 2011
 Reporter:  strk           |       Owner:  robe
     Type:  task           |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.0
Component:  documentation  |     Version:  trunk
 Keywords:                 |
 The function was added in r7185
 It is using default args, and is documented right before the function
 definition.
 Should be documented in the manual page.
 Note that this is the first function using the
 next_left_edge/next_right_edge fields in the topology edge table, which
 means it will fail to give any meaningful answer against topologies with
 those fields not properly setup (as those constructed using
 AddEdge/AddFace at time of writing)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/959>
