[postgis-devel] [PostGIS] #957: [raster] rt_asgdalraster regress test fails
trac at osgeo.org
Wed May 18 02:30:06 PDT 2011
Reporter: strk | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Description changed by strk:
Old description:
> --- rt_asgdalraster_expected 2011-05-17 09:50:39.000000000 +0200
> +++ /tmp/pgis_reg_9436/test_10_out 2011-05-17 17:05:26.000000000
> +0200
> @@ -11,5 +11,5 @@
> f0de16a21de438249ec0bbd28eafe63c
> ed4e4d60d2ccc82c4597e80c1f97272f
> 83b6012757444ff7786b5e8473e6cea3
> -b699be9f7045656edbb14ecec1c75b5a
> -96a96f9a6d31544dfc5ba5cd25f40934
> +f6fa7f8ae3c35c137a75acc855255083
> +7031666f7a668577b9de9cc6a8799f75
> --- rt_summarystats_expected 2011-05-17 09:50:39.000000000 +0200
> +++ /tmp/pgis_reg_9436/test_27_out 2011-05-17 17:05:27.000000000
> +0200
> @@ -5,7 +5,7 @@
> -3.429205|6.570795
> -0.068584|1.045941
> BEGIN
> -SELECT 10
> +SELECT
> 20|-3.429205|6.570795|-10|3.14159
> 1000|-0.068584|1.045941|-10|3.14159
> --- rt_mean_expected 2011-05-17 09:50:39.000000000 +0200
> +++ /tmp/pgis_reg_9436/test_28_out 2011-05-17 17:05:27.000000000
> +0200
> @@ -3,7 +3,7 @@
> -3.429205
> -0.068584
> BEGIN
> -SELECT 10
> +SELECT
> -3.429205
> -0.068584
> -3.429205
> --- rt_stddev_expected 2011-05-17 09:50:39.000000000 +0200
> +++ /tmp/pgis_reg_9436/test_29_out 2011-05-17 17:05:27.000000000
> +0200
> @@ -3,7 +3,7 @@
> 6.570795
> 1.045941
> BEGIN
> -SELECT 10
> +SELECT
> 6.570795
> 1.045941
> 6.570795
> The above is with PostgreSQL 8.4, PostGIS r7171, GDAL 1.9.0 on a 64bit
> system.
> I guess we should strip the 'SELECT' lines out of output.
New description:
+0200
@@ -11,5 +11,5 @@
The above is with PostgreSQL 8.4, PostGIS r7171, GDAL 1.9.0 revision 21597
on a 64bit system.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/957#comment:5>
