[postgis-devel] [PostGIS] #960: Start reducing number of functions by using defaults
PostGIS trac at osgeo.org
Wed May 18 04:20:12 PDT 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by pracine):
 What about:
   bytea ST_AsTIFF(raster rast[, text[] options][, text srs]);
 instead? (with italic stating at the first bracket) This is the Python doc
 way.
 What about the default values?:
   bytea ST_AsTIFF(raster rast[, integer[] nbands=ARRAY[1]][, integer
 compression=""][, integer srs=sameassource]);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/960#comment:1>
