[postgis-devel] [PostGIS] #963: Stop downloading DTDs
trac at osgeo.org
Thu May 19 13:14:57 PDT 2011
Reporter: robe | Owner: chodgson
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: management | Version: trunk
Keywords: |
Comment(by robe):
Good point. Our tar ball is big enough anyway. If it's not too much
trouble it would be better to install it on the server. Like I said it's
really Hudson giving false fails that is annoying because then you don't
know if it's w3c or a real failure, not to mention when it happens you
can't see your doc updates on the site right away.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/963#comment:7>
