[postgis-devel] [postgis-users] how to keep geometry_columns in sync wit tablesand views (and new PostGIS 2.0 plans)
Paragon Corporation lr at pcorp.us
Fri May 20 00:15:26 PDT 2011
One other note -- the SQL/MM standard calls for an st_geometry_columns view
which is a true view that reads the system catalogs and should only read the
system catalogs I think.
geometry_columns is a left over from OGC standard.  So my other point is if
we are going to do things the new way, why don't we call it the new name
"st_geometry_columns"
So that is why I was proposing a hybrid -- geometry_columns  -- so new
PostGIS can work with older tools
and st_geometry_columns -- which will be strictly pure new way.
Though I suppose that may be more confusing than it's worth and there is the
case of views
such as the form
SELECT .. ST_Transform(..,) As geom
Which for performance reasons should not be inspected and can not be
appropriately represented in system catalogs using typmod approach.
Thanks,
Regina
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ben
Madin
Sent: Friday, May 20, 2011 1:40 AM
To: PostGIS Users Discussion
Cc: 'PostGIS Development Discussion'
Subject: Re: [postgis-users] how to keep geometry_columns in sync wit
Thanks for the heads-up Regina,
I'm not really over most of the issues with type etc, but from my
perspective :
I'm not a big fan of doing things because of specifications written in the
past - I've never really understood the geometry_columns table as anything
except a metadata table - and while I'm sure that there are advantages in
terms of clients connection management, as someone who rarely has more than
50 -80 tables (each with only 1 or 2 geometry columns) and only Gigabytes of
data, not Terabytes, since the introduction of functions like
populate_geometry_columns(), I've not worried too much about it. It was a
pain prior to that!
My concerns (from my use case!) would relate to the risk that clients might
struggle to find a table that doesn't exist, or isn't the one that is
updated. I suspect that applications under current development would / could
be changed, and those that are older may not support the update to 2.0
anyway. Probably better not to go the hybrid route - it might get worse than
ugly.
If you are going to make a change, I agree that a major version is the time
to do it. We would probably selectively not migrate certain applications
rather than going down the line of upgrading and rewriting code - I don't
suppose that is a surprise to many people!
cheers
Ben
On 20/05/2011, at 1:26 AM, Paragon Corporation wrote:
Populate_Geometry_Columns is a function introduced in PostGIS 1.4. So yes
you are right the probe_geometry_columns is a lighter weight that doesn't
look at views and just looks at the constraints of tables.
Speaking of this.  In PostGIS 2.0, the plan is to use typmod support for
geometry (like what we currently have for geography)  as well and make
geometry_columns a view instead of a table as it is now
There are a couple of issues with this:
1) Existing data does not use typmod so there is a portability question of
if people want to use the new geometry_columns should they be forced to
convert their data to typmod.
(I say no).
2) Exotic uses of geometry_columns that inspecting the system catalogs will
not handle (e.g. views and other reasons for manual registration)
Anyrate the thread is outlined here:
http://trac.osgeo.org/postgis/ticket/944
I think the typmod is a done deal -- we are all in agreement we want this.
What is not a done deal is how best to formulate geometry_columns view.
I proposed a hybrid -- where part of the geometry_columns view reads from
the system catalog and the other part reads from a static table (basically
old geometry_columns table would be renamed and populate and so forth would
be changed to add to this table).
Anyway I admit the hybrid is less than pretty, but the alternatives look
even more ugly to me from a migration standpoint and supporting more exotic
uses.
We'd be interested in hearing how people feel about these approaches and any
other ideas as to how we can fuse the old with the new.
Thanks,
Regina
http://www.postgis.us <http://www.postgis.us/>
  _____
Madin
Sent: Wednesday, May 18, 2011 9:27 PM
To: pcreso at pcreso.com; PostGIS Users Discussion
Subject: Re: [postgis-users] how to keep geometry_columns in sync with
tables and views
G'day Brent,
I'm forever creating tables as subsets of existing tables so it is a truly
useful function, however, I've suffered the same concerns - perhaps it is
worth pursuing the name being changed?
I've also never really understood the distinction between the populate_ and
the probe_ functions? the probe_ one appears to be a 'lite' version, but it
may have some other purpose that I don't understand?
cheers
Ben
On 19/05/2011, at 9:02 AM, pcreso at pcreso.com wrote:
I foubd this an unfortunately ambiguous name.
it doesn't populate geometry columns so much as update the geometry_columns
table.
But irrespective of the name, it is nice to have :-)
Cheers
  Brent Wood
--- On Thu, 5/19/11, Ben Madin <lists at remoteinformation.com.au> wrote:
From: Ben Madin <lists at remoteinformation.com.au>
tables and views
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Date: Thursday, May 19, 2011, 12:50 PM
Ge,
Try
    SELECT Populate_Geometry_Columns();
http://postgis.refractions.net/docs/Populate_Geometry_Columns.html
which promises to truncate the geometry columns table first, then rebuild
it.
cheers
Ben
On 18/05/2011, at 8:05 PM, G. van Es wrote:
Hi Edward,
This will not work because this function doesn't do anything with views.
Also stale records aren't removed.
Ge
--- On Wed, 5/18/11, Edward Mac Gillavry <emacgillavry at hotmail.com
<x-msg://119/mc/compose?to=emacgillavry@hotmail.com> > wrote:
From: Edward Mac Gillavry <emacgillavry at hotmail.com
tables and views
To: postgis-users at postgis.refractions.net
<x-msg://119/mc/compose?to=postgis-users@postgis.refractions.net>
Date: Wednesday, May 18, 2011, 4:57 AM
Hi Ge,
You may want to check Probe_Geometry_Columns
(http://postgis.refractions.net/docs/Probe_Geometry_Columns.html).
Kind regards,
Edward
  _____
Date: Wed, 18 May 2011 04:38:51 -0700
From: gves2000 at yahoo.com <x-msg://119/mc/compose?to=gves2000@yahoo.com>
Subject: [postgis-users] how to keep geometry_columns in sync with tables
and views
Hi All,
We have a lot of tables and views updated, or better said, replaced on a
daily basis. We have seen that under certain conditions (which are unclear)
entries of the geometry_columns table are removed. So a mismatch occurs so
now and then resulting in showing either no data or being very slow when an
application has to do a table scan to obtain the geometry type.
What I like to have is a procedure which checks all tables and views against
the geometry_columns table and makes if necessary the right corrections.
Before inventing the wheel again, does anyone know if this procedure already
exist or knows perhaps another/better way to achieve this?
Thanks in advance,
Ge
_______________________________________________ postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
-----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20110520/71b25039/attachment.html>
