[postgis-devel] [PostGIS] #965: ST_AddIsoNode allows adding non-isolated nodes (nodes with containing_face=null)
trac at osgeo.org
Fri May 20 01:54:07 PDT 2011
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
According to SQL/MM, the ST_AddIsoNode function allows passing 'null' as
the "containing face". This is allowed specifically for the case in which
an isolated node is not inside a face.
Now, since the same document also refers to an "universal face", which has
(again, in the spec) a special face identifier 0, I guess that's the value
we should write in "containing_face" field of the node table, to
distinguish the node from a non-isolated one.
This would be pretty much equivalent to forbid passin 'null' and allow
passing '0', but the specs are confusing on the matter.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/965>
