[postgis-devel] [PostGIS] #957: [raster] rt_asgdalraster	regress test fails
    trac at osgeo.org
    Fri May 20 07:07:34 PDT 2011
 Reporter:  strk            |       Owner:  dustymugs
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 Updated to r7202.  ST_AsGDALRaster fails for me.  I get the exact same
 "new" hashes as in your test 10 diff in 32-bit linux with GDAL 1.8.0.  I'm
 going to have to dump out the rasters themselves and double-check them
 with GDAL to make sure that the outputs are correct.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/957#comment:15>
