[postgis-devel] [PostGIS] #967: [raster] raster regress failures - raster functions not being installed right during regress
PostGIS trac at osgeo.org
Fri May 20 14:16:36 PDT 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 This is a followup to Paul's comment.
 http://postgis.refractions.net/pipermail/postgis-
 devel/2011-May/013066.html
 I took get the same failures -- run tests: 53
 failed: 40
 I apologize for not having brought it up earlier. I just assumed it was an
 isolated mingw issue.
 Anyrate on further inspection -- the errors are largely because raster
 fails installation partly.
 I have no raster operators installed under regress install (though all
 installs fine under regular conditions).
 Just to point out the bogusness of these errors
 select st_isempty(rast) from empty_raster_test;
 fails with function st_isempty(raster) does not exist
 Works fine via my script install.
 When I compare the postgis_reg to my standard install,
 I see that for postgis_reg, none of the raster casts are installed though
 the raster type does exist.
 So all the tests that rely on raster 2 geometry casts fail.
 The only thing I see suspicious in the regress log is this
 psql:c:/projects/PostGIS/trunk/regress/../raster/test/regress/rtpostgis.sql:1471:
 ERROR:  cannot change name of input parameter "pixeltype"
 HINT:  Use DROP FUNCTION first.
 But I don't get that error during my regular install of raster
Ticket URL: <http://trac.osgeo.org/postgis/ticket/967>
