[postgis-devel] [PostGIS] #973: ST_GetFaceGeometry - don't intercept the UniverseFace
PostGIS trac at osgeo.org
Sat May 21 15:06:09 PDT 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
 when executing:
 SELECT topology.ST_GetFaceGeometry('topo_test2',0);
 the ST_GetFaceGeometry should return, as ask from the ISO specs,
  an exception like:
 "SQL/MM Spatial Exception - universal face has no geometry"
 instead wrongly the ST_GetFaceGeometry return a record with NULL value.
 I guess this is the reason of error reported in the ticket
 http://trac.osgeo.org/postgis/ticket/972
Ticket URL: <http://trac.osgeo.org/postgis/ticket/973>
