[postgis-devel] [PostGIS] #975: ST_AddEdgeNewFaces - wrong assigned face to nodes
trac at osgeo.org
Sun May 22 03:42:04 PDT 2011
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
Following the trace of ticket
http://trac.osgeo.org/postgis/ticket/972
I found the ST_AddEdgeNewFaces assign a wrong value to the
nodes. Actually it do this code:
-- NOT IN THE SPECS...
-- set containing_face = null for start_node and end_node
-- if they where isolated
IF span.was_isolated OR epan.was_isolated THEN
EXECUTE 'UPDATE ' || quote_ident(atopology)
|| '.node SET containing_face = null WHERE node_id IN ('
|| anode || ',' || anothernode || ')';
END IF;
Assigning a NULL value to isolated nodes.
I guess accordig to ISO specs.
It should not assign NULL if a node is isolated because an isolated node
still can be into a face.
Instead it should do this test:
if adding this edge will born some new face or split other faces.
It should be search for all nodes inside these faces and reassing the
containing_value.
I guess no change to node should be do if don't born or split a face.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/975>
