[postgis-devel] Out of DB regression tests for ST_AsGDALRaster
    Sandro Santilli
    strk at keybit.net
    Sun May 22 10:23:00 PDT 2011
On Sun, May 22, 2011 at 10:11:04AM -0700, Paul Ramsey wrote:
> same versions. MapServer is largely lacking regression tests because
> of issues in trying to compare "almost the same" image outputs. I
With Gnash, we implemented a FuzzyPixel class to test that the average
color around a given coordinate value (with a radius) is within a given
tolerance to a reference color value.
It works great when you know what to check and where.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
