[postgis-devel] [PostGIS] #978: ST_AddIsoEdge should raise an exception if any of the two given nodes has containing_face=null
trac at osgeo.org
Mon May 23 05:53:51 PDT 2011
Reporter: strk | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
Based on standard description for ST_AddIsoEdge you can't use the function
to create a non-isolated edge, which is an edge whose endnodes are shared
with another edge.
Rather than computing this sharing, the function could use the node's
"containing_face" field to tell if it was isolated or not.
Doing so would speed up operations and catch malformed topologies earlier
rather than tolerating them.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/978>
