[postgis-devel] [PostGIS] #978: ST_AddIsoEdge should raise an exception if any of the two given nodes has containing_face=null
trac at osgeo.org
Mon May 23 14:13:53 PDT 2011
Reporter: strk | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
Comment(by aperi2007):
I add the patch to this ticket.
http://trac.osgeo.org/postgis/attachment/ticket/978/patch_ST_AddIsoNode.zip
I patch the function and the sqlmm.sql, but also add a new regress test
ST_AddIsoNode.sql with others tests for an Isolated Node.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/978#comment:3>
