[postgis-devel] [PostGIS] #965: ST_AddIsoNode allows adding non-isolated nodes (nodes with containing_face=null)
trac at osgeo.org
Mon May 23 23:57:34 PDT 2011
Reporter: strk | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Resolution: fixed | Keywords:
Changes (by strk):
* status: assigned => closed
* resolution: => fixed
Comment:
The patch, slighly modified, was committed as r7222.
I noticed that the test is building its own topology, and filling up MBR
and using hexwkb to build it. It'd be easier to maintain if you used the
existing reference 'city_data' topology, as done by other recent tests.
The reference topology does have faces with holes and w/out holes,
isolated edges and pre-existing isolated nodes.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/965#comment:9>
