[postgis-devel] [PostGIS] #980: topology Regress failures on 9.1 beta - array_lower(topology.topoelementarray, integer) does not exist
PostGIS trac at osgeo.org
Tue May 24 03:57:39 PDT 2011
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by robe):
 strk,
 Don't bother fixing this.  The more I think about it the more I think this
 is a bug in PostgreSQL 9.1.  I was looking at my PostgreSQL 9.1 bea 1
 database in pgAdmin for example
 and topology.topoelementarray doesn't even display under domains nor under
 types, yet it does in my 9.0 equivalent database.  I'll report this to the
 authorities.
 So in short:
 SELECT array_upper(ARRAY[ARRAY[1,2],
 ARRAY[3,4]]::topology.topoelementarray,1);
 -- Works fine in 9.0 and 8.4
 In PostgreSQL 9.1 it throws a:
 function array_upper(topology.topoelementarray, integer) does not exist
 error
Ticket URL: <http://trac.osgeo.org/postgis/ticket/980#comment:2>
