[postgis-devel] map is not displayed using ms4w and postgis
Chris Hodgson
chodgson at refractions.net
Tue May 24 13:22:28 PDT 2011
This sounds like a question more appropriate for the users list. However
I think I see your problem - if you use capital letters in the name of a
table in postgres, you must quote that table name with double-quotes
("). How does this data statement work:
DATA 'the_geom from "Internal_plots"'
If that's not it look in the error log for mapserver (or in your web
server error log) - there should be an error message there that will
help you.
Chris
sanjib chatterjee wrote:
> Hi All,
> I am using geomoose2 framework + ms4w + postgresql 9.0 and postgis 1.5.
> While my mapscript use DATA from shape file and / or from mysql table
> ,map is generated and displayed well.
> but when it fetch from postgresql it fails to generate map. I am not
> getting any error message.
> Please help to find my problem.I am new in this area. I gave bellow my
> mapscript for shape,mysql and postgis.
> read from shape:-
> MAP
> NAME "Internal_plots"
> STATUS ON
> TRANSPARENT ON
> INCLUDE "../../../geomoose_globals.map"
> LEGEND
> STATUS ON
> LABEL
> TYPE TRUETYPE
> FONT vera_sans
> SIZE 8
> COLOR 0 0 0
> END
> END
> LAYER
> NAME Internal_plots
> STATUS ON
> TYPE POLYGON
> LABELITEM 'DAG_NO'
> TRANSPARENCY 100
> LABELCACHE ON
> CLASSITEM 'DAG_NO'
> DATA './Internal_plots'
> CLASS
> NAME 'dag_no'
> STYLE
> SYMBOL 'plainline'
> SIZE 1
> COLOR 255 255 255
> OUTLINECOLOR 0 0 0
> END
> LABEL
> TYPE TRUETYPE
> FONT vera_sans
> SIZE 10
> ANTIALIAS TRUE
> COLOR -1 -1 -1
> OUTLINECOLOR -1 -1 -1
> BUFFER 4
> MINFEATURESIZE auto
> PARTIALS FALSE
> POSITION cc
> END
> END
> METADATA
> 'identify_record'
> '../../Common/Template/village/identify_village.html'
> 'peak_record'
> '../../Common/Template/village/village_peak.html'
> 'select_record'
> '../../Common/Template/village/select_village.html'
> 'select_header'
> '../../Common/Template/village/select_header_village.html'
> 'popups'
> '../../Common/Template/village/village_popup.html'
> 'itemquery'
> '../../Common/Template/village/village_itemquery.html'
> # 'itemquery-filteritem' 'OWNER_NAME'
> 'itemquery-filter' '/.*[qstring].*/i'
> 'qstring_validation_pattern' '.'
> # Feature reports are stored in the conf/feature_report
> directory.
> 'feature_report' 'village.shp.xml'
> END
> TOLERANCE 0
> END
> END ## end Map
> ### report: work well
> Read from mysql , only DATA section,rest all are same
> CONNECTIONTYPE OGR
> CONNECTION "MySQL:bmaapp,user=root,password=root,port=3306"
> DATA "SELECT * from internal_plots ;"
> Read from postGIS only DATA section,rest all are same
> CONNECTIONTYPE postgis
> CONNECTION 'host=localhost port=5432 dbname=postgis user=postgres
> password=root at 2011'
> DATA 'the_geom from Internal_plots'
> ### report: map is not displayed
> please note that from pgadmin III sql query if we give select
> the_geom from public."Internal_plots" then gives the geomtry column
> as output but only select the_geom from Internal_plots OR
> the_geom from Internal_plots does not give output rather second one
> is syntax error and first one is giving message that Internal_plots
> relation does not exist.
> With Thanks and best regards
> Sanjib Chatterjee
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
