[postgis-devel] [PostGIS] #987: Bad handling of Inf values in GEOS
PostGIS trac at osgeo.org
Wed May 25 11:57:17 PDT 2011
 Reporter:  pramsey  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.3
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
 See http://postgis.refractions.net/pipermail/postgis-
 users/2011-February/028999.html
 Older versions of GEOS (pre 3.3) will loop infinitely when handed some
 coordinates with Inf values in them. Proj4 sometimes generates those
 values. The solution (?) in this case is to patch PostGIS to not pass the
 values through to GEOS.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/987>
