[postgis-devel] [PostGIS] #988: ST_AddEdgeNewFace - ambiguos error message for Empty Geometries
PostGIS trac at osgeo.org
Wed May 25 14:41:05 PDT 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
 testing the ST_AddEdgeNewFace using an empty geometry.
 I see it give an ambiguos message.
 This is the code I use:
 select topology.DropTopology('topo_test2');
 select topology.CreateTopology('topo_test2',3003);
 select
 topology.ST_AddIsoNode('topo_test2',0,ST_GeomFromEWKT('SRID=3003;POINT(1
 4)'));
 select
 topology.ST_AddIsoNode('topo_test2',0,ST_GeomFromEWKT('SRID=3003;POINT(2
 2)'));
 select
 topology.ST_AddIsoNode('topo_test2',0,ST_GeomFromEWKT('SRID=3003;POINT(6
 4)'));
 select
 topology.ST_AddIsoNode('topo_test2',0,ST_GeomFromEWKT('SRID=3003;POINT(4
 7)'));
 select
 4)'));
 select
 4)'));
 select
 6)'));
 select
 3)'));
 select topology.ST_AddIsoEdge('topo_test2',
     topology.GetNodeByPoint('topo_test2',
 ST_GeomFromEWKT('SRID=3003;POINT(1 4)'), 0),
 ST_GeomFromEWKT('SRID=3003;POINT(2 2)'), 0),
     ST_GeomFromEWKT('SRID=3003;LINESTRING(1 4, 2 2)')
 select topology.st_addedgenewfaces( 'topo_test2',
 ST_GeomFromEWKT('SRID=3003;POINT(6 4)'), 0),
     'LINESTRING EMPTY'::geometry
 The result error is:
  ERROR: Invalid edge (no two distinct nodes exist)
 The mex is ambiguos because it seem say that the error is due to two
 nodes.
 Instead the case Start-node and end-node coincident is allowed from ISO.
 The mex should be something like
  ERROR: Invalid edge (no two distinct vertex exist)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/988>
