[postgis-devel] [PostGIS] #990: [raster] ST_ValueProportion
trac at osgeo.org
Thu May 26 08:31:26 PDT 2011
Reporter: dustymugs | Owner: pracine
Type: task | Status: new
Priority: medium | Milestone: PostGIS Raster Future
Component: postgis raster | Version: trunk
Keywords: |
ST_ValueProportion is the sibling of ST_ValueCount and returns the
percentage of a raster's band that is of a specified value. To handle
floating point values, a rounding argument is provided.
1. ST_ValueProportion(rast raster, nband integer, hasnodata boolean,
search_value double precision, roundto double precision) -> double
precision
returns the percentage of the overall raster's bands pixel values that
a specific pixel value occurs
hasnodata: if FALSE, nodata values in band are considered in the
count. if TRUE, nodata values are not considered
value: the value to count in the raster
roundto: the decimal position to round a pixel value to. Originally
intended for use with 32BF and 64BF pixel types, it can also be used with
integers when round to the tens, hundreds or higher place.
examples are...
roundto < 0: no rounding
0: no rounding
0.1: round to the tenths place
0.01: round to the hundredths place
0.001: round to the thousandths place
1: round to the ones place
10: round to the tens place
100: round to the hundreds place
ST_ValueProportion(rast, 1, TRUE, 23, 0)
ST_ValueProportion(rast, 5, FALSE, 3.14, 0.01)
ST_ValueProportion(rast, 2, TRUE, 100, 100)
ST_ValueProportion(rast, 1, FALSE, -9999, 1)
2. ST_ValueProportion(rast raster, nband integer, search_value double
precision, roundto double precision) -> double precision
hasnodata is assumed to be TRUE
ST_ValueProportion(rast, 5, 3.14, 0.01)
ST_ValueProportion(rast, 2, 100, 100)
3. ST_ValueProportion(rast raster, nband integer, search_value double
roundto is assumed to be 0, so no rounding takes place. hasnodata is
assumed to be TRUE
ST_ValueProportion(rast, 1, -9999)
4. ST_ValueProportion(rast raster, search_value double precision, roundto
nband is assumed to be 1. hasnodata is assumed to be TRUE.
5. ST_ValueProportion(rast raster, search_value double precision) ->
double precision
nband is assumed to be 1. roundto is assumed to be 0, so no rounding
takes place. hasnodata is assumed to be TRUE.
A set of variations where more than one value parameter can be provided
should be added.
To count/get proportion of all unique values in a raster's band, the
search_value or search_values paramenter can be set to NULL.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/990>
