[postgis-devel] [PostGIS] #985: [raster] ST_Count
trac at osgeo.org
Fri May 27 13:28:33 PDT 2011
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: | Keywords: history
Comment(by dustymugs):
I think the ideal solution (at least for all the functions I've written)
is to eliminate the "hasnodata" function argument. If a band is flagged
as having nodata values and the nodata value is set, just the function run
with it. This assumes that the creator/maintainer of the raster knows
what they're doing so the function goes with what it is given.
There are no speed improvements for the "hasnodata" flag, just a filtering
one.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/985#comment:9>
