[postgis-devel] [PostGIS] #1000: box3d_extent output is 2d, casted to box3d makes up random numbers
trac at osgeo.org
Tue May 31 09:24:57 PDT 2011
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: boxes |
create table test (g geometry);
insert into test values ('POINT(0 0)');
insert into test values ('POINT(10 10)');
select st_extent(g) from test;
BOX(0 0,10 10)
select st_extent(g)::box3d from test;
BOX3D(0 0 6.90298898654887e-310,10 10 6.90298898647219e-310)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1000>
