[postgis-devel] [PostGIS] #1206: ST_Node
PostGIS trac at osgeo.org
Fri Nov 4 11:10:24 PDT 2011
#1206: ST_Node
 Reporter:  strk     |       Owner:  strk
     Type:  defect   |      Status:  assigned
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Description changed by strk:
Old description:
> A function taking a collection of lineal geometries and performing noding
> on them. There's a known trick of doing this with ST_Union, but the
> result is often over-splitted so takes an additional ST_LineMerge to do.
> Eventually, eving a separate entry point will allow further optimizing it
> or extending it.
New description:
 on them. There's a known trick of doing this with ST_Union, but the result
 Eventually, having a separate entry point will allow further optimizing or
 extending it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1206#comment:6>
