[postgis-devel] [PostGIS] #1267: [raster] Add manual height/weight support to ST_Resample (was: Add manuel height/weight support to ST_Resample)
trac at osgeo.org
Fri Nov 4 17:00:11 PDT 2011
Reporter: serveralex | Owner: pracine
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS Raster Future
Component: postgis raster | Version: trunk
Keywords: |
Changes (by dustymugs):
* type: defect => enhancement
* milestone: PostGIS 2.0.0 => PostGIS Raster Future
Comment:
The problem is that specifying the width/height is exclusive to that of
the X and Y scales. So, for ST_Resample(raster, reference_raster), should
the reference raster's scales be used or the dimensions? The assumption
that you're making about the resulting raster having the exact same
parameters as the reference raster is incorrect if the two rasters are
different (such as where the extent of one is larger than that of the
other).
Using the reference raster's scale makes sense for ST_Resample(raster,
reference_raster) as the default instead of the width and height because
the resampled raster has the same alignment with the reference raster.
This permits followup processing using a two raster mapalgebra function.
I'll add the options of specify a resampled raster's width/height to the
ST_Resample
variants. ST_Resample for a raster and a reference raster may need an
additional flag indicating whether or not to use scales or width/height.
So, instead of
CREATE OR REPLACE FUNCTION st_resample(
rast raster,
ref raster,
algorithm text DEFAULT 'NearestNeighbour',
maxerr double precision DEFAULT 0.125
add
rast raster,
ref raster,
usedimensions boolean DEFAULT FALSE,
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1267#comment:1>
