[postgis-devel] [PostGIS] #1266: postgis_gdal_version missing
trac at osgeo.org
Sat Nov 5 13:09:39 PDT 2011
Reporter: strk | Owner: pramsey
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Changes (by bnordgren):
* priority: medium => blocker
* status: closed => reopened
* resolution: fixed =>
Comment:
NOT FIXED!
r8100 breaks "make check" with
psql:/home/bnordgren/src/postgis/regress/postgis.sql:2239: ERROR: could
not access file "/home/bnordgren/src/postgis/regress/00-regress-
install/lib/rtpostgis-2.0": No such file or directory
This is with `./configure --with-raster`, `make` and `make check`
The directory listed above has postgis-2.0.so but not rtpostgis-2.0.so.
The error comes when make check is executing in the "postgis"
subdirectory, and occurs during the initialization of regression testing
(e.g., before any tests are run).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1266#comment:2>
