[postgis-devel] [PostGIS] #1252: SRID appearing in ST_AsText for particular multipolygon
Paragon Corporation
lr at pcorp.us
Sun Nov 6 15:35:38 PST 2011
Paul, strk,
I'm sure you are getting tired of me at this point. One more test before I
close this out as a wontfix and unsolved mystery.
I checked my windows 2008 32-bit install, though the ST_AsText looks normal,
the ST_Summary gives the same bizarre answer as the 64-bit one.
MultiPolygon[BS] with 6 elements
Polygon[S] with 1 rings
ring 0 has 201 points
Polygon[] with 1 rings
ring 0 has 213 points
ring 0 has 25 points
ring 0 has 78 points
ring 0 has 81 points
Polygon[] with 3 rings
ring 0 has 284 points
ring 1 has 22 points
ring 2 has 46 points
In PostGIS 2.0, I can't tell since we don't output the S anymore and
ST_AsText gives normal answer for both 32-bit and 64-bit. So I guess that
makes me feel a bit better that both give the same goofy answer.
strk -- can you verify on your 1.5 (not sure if Paul still has his)
If
SELECT ST_Summary(ST_Union(geom))
FROM (SELECT (ST_Dump(geom)).geom
FROM weird_mpoly) As foo ;
Is normal or gives the same strange answer. Just humor me a little.
Thanks,
Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of PostGIS
> Sent: Sunday, November 06, 2011 5:35 PM
> Cc: postgis-devel at postgis.refractions.net
> Subject: Re: [postgis-devel] [PostGIS] #1252: SRID appearing
> Reporter: robe | Owner: pramsey
> Type: defect | Status: new
> Priority: medium | Milestone: PostGIS 1.5.4
> Component: postgis | Version: 1.5.X
> Keywords: windows, 64-bit |
> Comment(by robe):
> Paul,
> I'm okay with closing this out as a wontfix, but fear it
> might be a sign of a bigger issue. The fact that it's not
> consistent across all platforms really bugs me as those
> often suggest not properly freeing memory.
> I guess I'm more bothered about the fact that it's only
> windows 64-bit that seems to be able to do this not the
> windows 32-bit one (though I don't think we have tested
> Linux 64-bit bit). I've always taken it for granted that
> PostGIS 32-bit on 64-bit windows would behave exactly the
> same as PostGIS 32-bit on windows 32-bit since they would
> bothe be using 32-bit space.
> This demonstrates it doesn't and I'm suspecting that the
> crashing in raster noted in #1066 might be a 32-bit vs.
> 64-bit windows issue too.
> Since Bborie can't reproduce the crash with my builds but I
> can on my 64-bit windows 7 desktop. I can only assume he is
> running windows xp 32-bit.
> Ticket URL: <http://trac.osgeo.org/postgis/ticket/1252#comment:15>
> PostGIS <http://trac.osgeo.org/postgis/> The PostGIS Trac is
> used for bug, enhancement & task tracking, a user and
> developer wiki, and a view into the subversion code
> repository of PostGIS project.
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
