[postgis-devel] [PostGIS] #1252: SRID appearing in ST_AsText for particular multipolygon
trac at osgeo.org
Mon Nov 7 09:15:31 PST 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.4
Component: postgis | Version: 1.5.X
Keywords: windows, 64-bit |
Comment(by strk):
Actually I can't reproduce the bug on my 32bit system with postgis
1.5.4SVN installed:
pgis15=# select st_summary(st_union(geom))
pgis15-# from (
pgis15(# select (st_dump('SRID=4326;MULTIPOLYGON(((0 0, 1 1, 1 0, 0
0)),((4 4, 4 5, 5 5, 4 4)))'::geometry)).geom
pgis15(# ) as foo;
st_summary
MultiPolygon[BS] with 2 elements
Polygon[] with 1 rings
ring 0 has 4 points
ring 0 has 4 points
(1 row)
Time manually review PG_FREE_IF_COPY calls ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1252#comment:20>
