[postgis-devel] [PostGIS] #1271: ST_Line_Locate_Point inaccurate closest point
trac at osgeo.org
Mon Nov 7 15:04:04 PST 2011
Reporter: strk | Owner: strk
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by nicklas):
I think you have a typo in r8107.
pa->npoints is 1-based, not 0-based, right?
Then shouldn't it be instead?:
if ( t >= pa->npoints &&
( proj.x == end.x) && (proj.y == end.y) )
That would explain it since the answer from st_closestpoint is the same as
the second last vertex, not the last.
/Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1271#comment:2>
