[postgis-devel] [PostGIS] #1274: ST_CreateTopoGeo failed
PostGIS trac at osgeo.org
Fri Nov 11 05:42:48 PST 2011
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 Oddly enough, interrupting the insertion of edges on error and querying
 the database I find 2 candidate points but both seem to be pretty far from
 each-other:
 =# with p as ( select
 '0101000000B0B7BE9F8369294180870580ACEA2841'::geometry g ) select node_id,
 st_distance(geom, p.g) from small_sample_topo.node, p where geom && p.g;
  node_id |     st_distance
     2515 | 3.97360129963356e-08
     2516 | 0.000998956812181611
 (2 rows)
 Now to figure out how did that point move... (hoping ST_Distance is _not_
 using bounding box)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1274#comment:3>
