[postgis-devel] [PostGIS] #1280: No geoms in table are within the table extent
trac at osgeo.org
Fri Nov 11 06:17:11 PST 2011
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
with ext as ( select st_extent(geom) as g from small_sample) select gid
from small_sample, ext where geom && ext.g;
No hits from the above. The table contains 22 items.
The table is here
http://trac.osgeo.org/postgis/attachment/ticket/1274/small_sample.sql.gz
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1280>
