[postgis-devel] Float vs Double Box
Mateusz Łoskot mateusz at loskot.net
Fri Nov 11 07:11:15 PST 2011
On 9 November 2011 17:43, Paul Ramsey <pramsey at opengeo.org> wrote:
> So, we've had this argument before, and Mark wanted double boxes for
> simplicity, and I wanted float boxes to keep index sizes down.
> And I realized on the way into work that actually we could have both,
Calculate using double, store/serialise in float.
Use of different sizes of float-point type in the same expression has
nearly zero effect on run-time performance. On memory side,
you stick to the same bandwidth.
(I'm forgetting here about possible side effects like precision of
operation is different than expected.)
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
