[postgis-devel] [PostGIS] #1283: ST_MapAlgebraFct 2 band version function proto looks wrong
    trac at osgeo.org
    Fri Nov 11 17:03:13 PST 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 I wonder if this is a pgAdmin bug.  When I install in 9.1:
 CREATE OR REPLACE FUNCTION st_mapalgebrafct(
         rast1 raster,
         rast2 raster,
         userfunction regprocedure,
         pixeltype text DEFAULT NULL, extenttype text DEFAULT
 'INTERSECTION',
         VARIADIC userargs text[] DEFAULT NULL
         RETURNS raster
         AS $$ SELECT st_mapalgebrafct($1, 1, $2, 1, $3, $4, $5, VARIADIC
 $6) $$
         LANGUAGE 'SQL' STABLE;
 and I look at what got installed in PgAdmin -- it shows me:
 CREATE OR REPLACE FUNCTION st_mapalgebrafct(IN rast1 raster, IN rast2
 raster, IN userfunction regprocedure DEFAULT NULL::text, IN pixeltype text
 DEFAULT 'INTERSECTION'::text, IN extenttype text DEFAULT NULL::text[],
 VARIADIC userargs text[])
   RETURNS raster AS
 ' SELECT st_mapalgebrafct($1, 1, $2, 1, $3, $4, $5, VARIADIC $6) '
   LANGUAGE sql STABLE
   COST 100;
 I'll experiment and see.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1283#comment:8>
