[postgis-devel] [PostGIS] #1293: ST_Resize to resize raster tiles
trac at osgeo.org
Mon Nov 14 07:44:23 PST 2011
Reporter: robe | Owner: pracine
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS Raster Future
Component: postgis raster | Version: trunk
Keywords: |
Comment(by dustymugs):
ST_Resize would use the same underlying function calls as gdal_translate.
ST_Rescale (ST_Resample) makes use the of the same underlying function
call as gdalwarp. To use ST_Resample, the raster must have a SRID. I ran
some basic tests on random pictures I had lying around (no spatial
reference) using gdalwarp (to test for behavior) and as expected returned
an error.
By the looks of it, gdal_translate will resize any image for you
regardless of spatial reference.
So for one of my random pictures
gdal_translate works.
gdalwarp -ts 1000 1000 0884Parkfl\ copy.jpg test.tif
gdalwarp doesn't. Error given is:
ERROR 1: Unable to compute a transformation between pixel/line
and georeferenced coordinates for 0884Parkfl copy.jpg.
There is no affine transformation and no GCPs.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1293#comment:2>
