[postgis-devel] [PostGIS] #1267: [raster] Add manual height/width support to ST_Resample
trac at osgeo.org
Mon Nov 14 13:40:39 PST 2011
Reporter: serveralex | Owner: dustymugs
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: fixed | Keywords: history
Changes (by dustymugs):
* keywords: => history
* status: assigned => closed
* resolution: => fixed
* milestone: PostGIS Raster Future => PostGIS 2.0.0
Comment:
Added support for width/height in r8153.
The function signature changes are:
_st_resample(
rast raster,
algorithm text DEFAULT 'NearestNeighbour', maxerr double precision
DEFAULT 0.125,
srid integer DEFAULT NULL,
scalex double precision DEFAULT 0, scaley double precision DEFAULT
0,
gridx double precision DEFAULT NULL, gridy double precision
DEFAULT NULL,
skewx double precision DEFAULT 0, skewy double precision DEFAULT
0,
width integer DEFAULT NULL, height integer DEFAULT NULL
width: the number of columns in the raster. width/height are mutually
exclusive to scalex/scaley
height: the number of rows in the raster. width/height are mutually
st_resample(
rast raster,
ref raster,
maxerr double precision DEFAULT 0.125,
usescale boolean DEFAULT TRUE
usescale: if FALSE, the reference raster's width and height are used
instead of the X and Y scales.
New function signatures are:
st_resample(
rast raster,
width integer, height integer,
DEFAULT NULL,
0,
DEFAULT 0.125
st_resample(
rast raster,
ref raster,
usescale boolean,
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1267#comment:11>
