[postgis-devel] [PostGIS] #1267: [raster] Add manual height/width support to ST_Resample
trac at osgeo.org
Tue Nov 15 07:14:17 PST 2011
Reporter: serveralex | Owner: dustymugs
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: fixed | Keywords: history
Changes (by dustymugs):
* status: reopened => closed
* resolution: => fixed
Comment:
As ST_Resample behaves the same way as GDAL gdalwarp utility, this latest
change maintains that behavior. gdalwarp does not permit specifying scale
and width/height at the same time.
http://gdal.org/gdalwarp.html
Look at switches -tr and -ts.
You can only have one or the other as they're dependent upon one another.
Using GDAL's suggested extent for the warped raster, you can compute the
dependent variable. If width/height is provided, the scales are computed
for the suggested extent. If scale is provided, the width and height are
also computed.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1267#comment:13>
