[postgis-devel] [PostGIS] #1301: Transforming from SRID 4267 to 4326 returns incorrect result
trac at osgeo.org
Tue Nov 15 23:36:25 PST 2011
Reporter: realityexists | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
PostGIS 2.0.0 as of 2011-11-08
select st_astext(st_transform(ST_GeomFromEWKT('SRID=4267;POINT(-70 10)'),
4326));
returns POINT(-1.22173047639603 0.174532925199433) which is way off.
However
select
st_astext(st_transform(st_transform(ST_GeomFromEWKT('SRID=4267;POINT(-70
10)'), 3395), 4326));
returns a point very close to the input, as expected.
In 1.5.3 the first query results in an error (see defect 318), so this is
not an entirely new issue. However, on 2.0.0 it returns a bad result,
which is worse, because the problem is much harder to detect.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1301>
